alas the speedometer goes to 20, then stays there.
Old 03-01-2012 | 08:42 PM
wrencredle's Avatar
Default alas the speedometer goes to 20, then stays there.
i know there a few threads on this already, but was wondering if my case is related. Speedometer was working fine (odometer was not running), then went to change out the cv axles and went to town on the nut to no avail. In the process we pulled the entire wheel back against the fender wall. well when we put it all back together , when I key the car to 2 position or start the car, the speedometer goes straight to 20mph, and stays there. Did we loosen a ground or something? and while im blabbering, the car is redlining at appx.5500 rpm, when the tach is marking the redline at 6200 appx. wth?
Old 03-01-2012 | 09:08 PM
Does the cruise control work when the speedometer is stuck at 19 mph?
Old 03-02-2012 | 05:49 PM
wrencredle's Avatar
yep the cruise control works
Old 03-02-2012 | 06:29 PM
Then the problem is definitely with the speedometer. If you remove the cluster, you can take it apart. There is a small green circuit board on the back of the speedometer that is the likely culprit. You can try redoing the solder joints if you know how to solder. If not, you can swap that board with a known working board, so your mileage is accurate. You could swap with a used speedometer, but the mileage will be wrong.
Old 03-02-2012 | 08:30 PM
wrencredle's Avatar
Ah I just googled the infamous 20mph speedo problem on 94-97 accords. So if the vss is working(and thats the sensor on the top of the transmission right?) then it pretty much is the speedometer? cuz i really dont want to pull the dash if i dont have to.
Old 03-02-2012 | 08:51 PM
That is correct. It is the speedometer.
Removing the cluster isn't too bad. In the common diy thread on top of the gen tech help forum, there is a link to the online manuals thread. From there you can get a 94 shop manual that will show you how to remove the cluster.
The dash doesn't need removed. The center console, radio bezel, radio, HVAC panel, then the cluster. It sounds like a lot, but it isn't complicated.
Old 10-23-2013 | 09:10 AM
wrencredle's Avatar
Will a speedometer from a 94 automatic accord, work in my 94 5 speed? I know the whole cluster is different but is the actual speedometer compatible?
Old 10-23-2013 | 07:04 PM
The PCB should swap over without issues.
tpstaples
10-05-2021 05:53 AM
fireball
03-03-2011 09:05 PM
SolEX01
08-10-2010 05:04 PM
pdude
07-17-2008 07:46 AM
ryanmunce
05-29-2007 06:42 PM
Quick Reply: alas the speedometer goes to 20, then stays there.
