Antifreeze vent valve
Just finishing up the timing belt and associated goodies on my wifes 2001 EX coupe 4cyl and kind find the cooling system vent valve mentioned in most of the writeups I've read. Sounds like it should be close to the thermostat housing but the only thing I can find is a small plug to the left and behind the housing that is actually below the stat level. Doesn't seem right because it's lower. Does my car not have a vent?
Thanks for all the info that got me through the timing belt swap!
Thanks!
Thanks!
RE: Antifreeze vent valve
Never did find that vent valve but the wife has put about 2000 miles on the change at this point.
Couple more questions on the timing belt...I'm still waiting for my manual I ordered about a month ago.
How often should I go through the timing belt tightening sequence or should I ever do it again?
Thanks
Thanks
