ATF Drain Plug
ATF Drain Plug
Hello all,
So, today I went to do a ATF drain and fill on my 92 Accord EX...2 door, if that makes a difference. I get under the car and am suprised to not see an obvious drain plug for the transmission. Its on the passenger side I think...Can anyone explain where the plug may be found please? Thank you.
RE: ATF Drain Plug
Yes the passenger side, look for a bolt with a square hole in it. Amazingly a 3/8" breaker bar will fit right into that square hole.
[IMG]local://upfiles/5417/8204754060D8451A99B494DA2D1CEF19.jpg[/IMG]
RE: ATF Drain Plug
I just did that on my '94. It can be removed without jacking the car up (on mine). It's at the bottom of the case, facing the wheel, just behind a suspension(torsion?) bar. It's fitted with a 3/8" socket, making it very easy to remove.
Max Utility
04-16-2012 05:47 PM
jon02accord
03-26-2008 11:54 AM
