auto-tranny swap 4-cyl 2002 into 1998?
Old 09-28-2009 | 04:41 PM
92accord808's Avatar
Default auto-tranny swap 4-cyl 2002 into 1998?
what is the difference between the 98accord F23A Vtec and 02accord F23A4 non Vtec.
is the non Vtec more fuel efficient?
are the two interchangeable?
tnx.
Old 09-28-2009 | 05:15 PM
F23A (without a number at the end) wasn't a USA engine.
F23A1 = VTEC = "basic" engine in 49-state Accord EX, probably LX
F23A5 = ULEV VTEC = cleaner exhaust for California emmissions rules
F23A4 = non-VTEC = cheaper engine, maybe Accord DX??
The non-VTEC engine is cheaper but less powerful. From one year to the next, I'm not sure which version Accord comes with each engine.
They're kinda interchangable, but there's issues. The VTEC engine has a couple extra things on the wiring harness & the ECU is different.
The ULEV engine (F23A5) has a LOT of changes in the ECU, wiring harness, sensors, etc. That one's not easy to swap.
Old 09-28-2009 | 05:29 PM
your right its a f23A1.
i have a bad tranny on my 98accord Vtec, it jerks when going down to first gear.
so this mean that i cant use the F23A4 non vtec to replace my tranny?
is there a way because i already bought the tranny for $500.
pls pls pls help.....
Old 09-29-2009 | 12:52 AM
so any one knows if i can use the non vtec tranny to vtec engine.
what are the mods i need to do.
Old 09-29-2009 | 08:04 AM
I'm sorry, I thought the question was about the engines, not about the trannys.
I think the trannys are the same, but I'm not completely sure.
Old 09-29-2009 | 02:38 PM
i just want to make sure before ill spend money on the installation and ending up not working. pls help me
Old 09-29-2009 | 03:43 PM
I don't know for sure, but I changed the thread title so maybe someone will know.
Old 09-29-2009 | 04:22 PM
I went to car-part [dot] com and looked up a part for a 98 transmission.
It only asked if it was a 2.3 automatic and didn't ask for LX/DX/EX like it would for the engine. It looks like they have the same transmission.
Look for the number stamped on the two transmissions. If they are the same, then you are good to go.
Old 09-30-2009 | 01:01 AM
i found the code
from my car 98 lx: BAXA-5160501
WPAX30
from junk yard 02 Dx: BAXA-9036779
2PAX03
so are they interchangeable?
Old 09-30-2009 | 04:36 PM
On the 94-97 accords, the first four digits (BAXA) are the transmission number. The rest are the serial number that is unique to each transmission.
My guess is that your 98 is the same. So they should be able to be swapped without any other modifications.
This info would be in a 98 shop manual which you can download from the online manuals link in the diy section. Its an .iso file, so you have to burn it to a CD for it to work. If you are doing a swap, you should have a shop manual to help you.
NeyVtec
04-11-2015 01:57 AM
1999HondaAccordEXV6coupe
05-09-2012 03:28 PM
fordmechanic
03-17-2011 09:38 PM
bigdawg74
02-20-2010 12:20 PM
