Automatic Transmission Fluid Change?
I have a 1990 Accord EX with a lot of miles on it. Is it a good idea to change the Transmission Fluid? I'm worried it might cause problems? I don't have much experience with Honda Transmissions, so any advice would be great....Thanks
How would NOT changing the transmission fluid be a good idea?
Honda trannys have an internal filter that is essentially non serviceable. You need to be changing that fluid ever 30k miles or so by draining 2.5 quarts, refilling and do this 3 times total to get most of the fluid changed. Of course, this is assuming it is the same as the 94-97 gen.
93Accord2.2
12-17-2021 10:59 AM
62maxx
10-18-2015 09:20 AM
