Bad low fuel light
Actually no I didn't. I don't exactly know how to do that, I just assumed it was bad cause it was a hazy black in the bulb when I was changing the others in my cluster. Any info on how I would check the censor?
Remove the cover for your spare tire. Near the back seat in the trunk, remove the access panel to the fuel gauge sending unit. Unplug the 5-pin connector. Jump the light green/red strip wire to ground with a piece of wire. See if the light turns on with the key in the II position. Also jump the ltgrn/red wire to the black wire on the connector and see if the low fuel light turns on (this test the black wire in your trunk).
Pajamarama
08-27-2012 06:12 PM
