battery dying, jumper cable from battery to ac compressor
Old 07-13-2011 | 12:48 PM
Adler's Avatar
Maybe you've already done this but check the fuse! (wouldn't that be nice)
Old 07-14-2011 | 02:24 PM
cadams8221218's Avatar
I havent do anytl tests but am goingto go ahead and just get another ac compressor. I will check back and get help with my drivers side radiator fan that isn't spinning as well. Thanks guys
Old 07-14-2011 | 03:13 PM
Adler's Avatar
Why would you do that? the compressor is one of the only components proven to be working!!!
Old 07-14-2011 | 09:26 PM
I'm going to get another compressor because the only way to get it to work properly is to put a jumper on it from the battery. For now I just unhook the wire from the battery when my car sits overnight. Then when I get ready to drive just hook it back up. Its crazy but gives me cold ac. I live in Baltimore. Sum hot days round this time.
Old 07-14-2011 | 09:48 PM
Adler's Avatar
The fact that your compressor works when you jumper it indicated that it is working and that the issue lies in the wiring.
Old 07-14-2011 | 09:54 PM
R u sure. My mechanic said I need a new one. Also sum people in this thread said it wouldn't engage and that is y the guy put a jumper on it. So what do u suggest I do to figure out y it won't work without the jumper. Thx for the help
  #17
Old 07-14-2011 | 10:07 PM
Adler's Avatar
You need to find out why the compressor isn't receiving 12v when the AC is on. I would check the fuse and make sure that the relay is clicking when you hit the AC button. If those don't shed some light then you will need a wiring diagram or a diagnostic flow chart to help you track down the problem.
  #18
Old 07-14-2011 | 10:14 PM
If your a/c is blowing cold right now, then the compressor is not your problem. Replacing your compressor will be a waste of money.
It is likely that you have a fuse, a relay, or a wiring problem that will be much less expensive for you to fix.
Check for voltage on the red wire that goes to your a/c compressor when you don't have the jumper wire connected when the a/c should be running. Let us know if you have battery voltage (~12V).
  #19
Old 07-14-2011 | 11:29 PM
I check all my fuses that i thought were necessary And they all were good what fuse would I check tho. N I'll get a multimeter tomorrow and check the voltage
  #20
Old 07-14-2011 | 11:34 PM
What fuses should I check
Quick Reply: battery dying, jumper cable from battery to ac compressor
