Battery terminal bolt won't tighten
My car battery negative terminal bolt is so loose that it come off.
I failed to tighten it with a 10MM socket wrench.
Please note that I can tighten my car battery positive terminal bolt.
Please see the attached photos.
How to tighten the 10MM car battery negative terminal bolt?
A battery post shim may fix it, which are sold at auto parts stores.
Some people just stick something that is conductive metal in between the terminal; but, a shim made for the post is better.
seattleslew
06-05-2013 11:53 PM
