Battery warranty??
Battery warranty??
I tried searching and couldn't find.
Anyone know the warranty information for the battery?
I looked through my Warranty Manual and I could have sworn it was still under warranty (car purchased 12/04; ~35k miles). I brought my car in to the dealership and he says battery needs replacing and it's not under warranty. Can anyone shed light on this issue for me? Thanks!!
RE: Battery warranty??
As far as I know the battery falls under the 3/36 standard warranty.
It could be that the dealer has no service records for you and your vehicle and decided you are just a 'warranty hound'. Unfair I admit, but it is the real world.
There is a Phone number in your owners manual for American Honda Customer Care.
Maybe you could call them and explain the entire situation to them;
But I do ask you, if you get a survey card in the mail, and mark anything less than 'excellent' the survey will be considered as a failure and the butthead service advisor will still get his normal pay, the A$$hole Service manager will still get his monthly bonus, Parts guys have no problems with a bad survey......The Tech in the shop that worked on your car will have his pay cut for a month at least, some dealerships take away as much as a dollar an hour for up to 6 months.
Thats the way the "reynolds & reynolds " system works.
Even if parts are not in stock when the car is being worked on the mechanic gets the pay cut for any reason you are unhappy.
ORIGINAL: hondadude
I thought the battery was covered by it's own warranty, just like when you buy a new battery. Namely full replacement for the first xx months then pro-rated out to? years. (But I'm too lazy to go look at my warranty booklet.)
most batteries will be covered with at least a 60 month warranty before they go into the pro-rated replacement. just gotta make sure that you have a healthy electrical system and a good alternator before you go in and try to get a new battery.
usually warranty is 12 tp 24 months depending on manufact ,, after that battery is pro-rated ( meaning you only pay for what you have used ) till up to 60 months ,, again depending on manufact ..
even if battery was out of warranty there is still some pro-rated left
but i was under the impression that Honda warrantied them for 3 yrs , 36k mles (.i am .not 100% sure )
Antiriad
12-31-2013 09:48 AM
cadams8221218
07-15-2011 07:24 AM
mchabukswar
06-17-2011 08:55 AM
RoKnAzn
01-19-2007 01:56 PM
