Beater with Heater Part II
Now that we have a handle on the ABS issue another issue has reared its head.
The turn signal/hi-lo switch quit working. left and right work, but it is stuck on low beams.
Can this be replaced without removing the steering wheel?
Thanks
Steve
Thanks
Steve
You'll have to remove just the plastic covers. That TRQ channel on YouTube also has a how to video on the combination switch.
Once removed, you can disassemble the switch to clean the internal contacts and relubricate with some dielectric grease if you want to try the very cheap route to fix.
