best air filter for Accord 2000 EX V6
Old 01-15-2013 | 08:21 PM
Wazari's Avatar
Volumetric efficiency of an engine changes very little if at all with a K & N or other cotton media type air filters unless you have done extensive modifications to your ports, exhaust system and cam specs. Also while these oiled cotton gauze filters may "flow" a little better, then also let in more dirt and a big part of engine wear in street engines is caused by dirt particles 5 to 30 microns is size. Unless you're running a highly modified engine or one with forced induction, then all an aftermarket oil-type filter is going to do your stock motor is cause slightly faster cylinder wall wear.
Old 01-16-2013 | 11:57 AM
Technocrat's Avatar
Yes, I am aware but that would probably mean that the engine would need work at 200k instead of 300k or so, I don't intend to keep the car that long anyways, so till the time its with me, I should be good
Old 01-16-2013 | 01:52 PM
shipo's Avatar
I've seen engines which used crap low restriction filters ruin the engine bearings in as little as fifty to sixty thousand miles. Like it or don't, for a daily driver there really is no replacement for an OEM spec air filter.
Old 01-16-2013 | 01:54 PM
Jet sitter's Avatar
^So far I've run the K&N filter for at least 160K miles.
Old 01-16-2013 | 02:30 PM
shipo's Avatar
Louisville, KY doesn't exactly qualify as a dusty environment; you could probably do as well with no airfilter at all.
Old 01-16-2013 | 03:44 PM
Technocrat's Avatar
Its not a daily driver but it is my only car.
If not the Typhoon, I would surely go for stock replacement filter from K&N. Have had a good experience before with a K&N replacement filter on a much smaller car & in a much Dusty environment.
  #17
Old 01-16-2013 | 04:46 PM
shipo's Avatar
How do you know you had a good experience with your previous K&N; did you have your oil analyzed before and after you started using it so you can confirm contaminates like silicone (aka. sand) remained low?
  #18
Old 01-16-2013 | 06:52 PM
Jet sitter's Avatar
I love your F4U Corsair, it's my favorite aircraft of all time.
  #19
Old 01-17-2013 | 05:28 AM
shipo's Avatar
Thanks, mine too.
  #20
Old 01-17-2013 | 08:07 AM
valvelash's Avatar
Its THE most important filter on the the whole car, dont go cheap. I'd buy from Honda.
