Best Chemicals to Clean your engine with
Old 12-28-2008 | 11:30 PM
Roadrash98vtec's Avatar
Default Best Chemicals to Clean your engine with
Well it seems to me that theres a lot of products on the market that claim to help clean your engine and restore horsepower and I was wondering out of all the products out there whats the best product that you recommend in cleaning your internals
Like stuff you add to the gas tank to clean injectors / fuel systems
and other chemicals you add to the oil to clean cylinder walls and restore compression
whats your favorite and outlooks
Old 12-29-2008 | 12:29 AM
popejoshpope's Avatar
Default RE: Best Chemicals to Clean your engine with
Seafoam. Seafoam. Seafoam!!!!! its the bomb. it works really well. You but 1/3 of the can in the crankcase. 1/3 in the brake booster line. And 1/3 in the gas tank
[ul][*]Cleans fuel injectors[*]Cleans carburetor jets[*]Cleans carbon[*]Stabilizes fuels[*]Upper cylinder lube[*]Removes moisture in fuel[*]De-icer
Frees sticky lifters
Frees sticky rings
Removes moisture in oil
Cleans P.C.V. systems
Cleans catalytic converter odors
Oxygen sensor safe [/ul]
source: http://www.seafoamsales.com/motorTuneUpTechGas.htm
it works very well and when you start your car, a butt load of smoke comes out. FUNNNNN!!!!!
http://www.youtube.com/watch?v=yhn5_laDaIU
(is was not paid for this)
Old 12-29-2008 | 12:47 AM
Where do you put it in the crank case? Cuz i know the brake booster one
Old 12-29-2008 | 01:01 AM
finch13's Avatar
Put it in the oil to do the crankcase one. I usually do 1/2 in the gas and half in the oil.
Old 12-29-2008 | 01:48 AM
But ive heard change the oil afterwards because it thins your oil out.....Finch, any input on that
when i did it, I did 1/2 BBL and 1/2 gas tank
Old 12-29-2008 | 04:58 PM
So put about a third in the oil fill.
put a third in the vaccum line
and and the rest in the gas tank
Old 12-29-2008 | 04:59 PM
falkore24's Avatar
IMO, Seafoam is good for the BBL. MMO is better for the crankcase and I like Lucas in the gas.
the cyclops
07-24-2011 04:05 PM
zendao
01-13-2011 01:17 PM
sacramentoaccord
06-02-2009 11:48 AM
wyperiod
06-12-2008 12:11 AM
sir_nasty
01-17-2007 12:58 AM
Quick Reply: Best Chemicals to Clean your engine with
