blinking oil indicator light
Old 11-15-2006 | 05:43 PM
shoispo
Default blinking oil indicator light
I have a 91 accord lx. The oil indicator light starts blinking usually as I get off the freeway (go from high to low rpm's). When I shut off the car and turn it on again it stops. Does anyone know what this could mean? Thanks in advance.
Old 11-15-2006 | 05:46 PM
Slusher's Avatar
Default RE: blinking oil indicator light
it usually means low oil, better check it out.
Old 11-15-2006 | 06:10 PM
shoispo
I drove it yesterday from CA to Idaho and changed the oil the day before I left (so its full). Could the temp have anything to do with it?
Old 11-15-2006 | 06:23 PM
sir_nasty's Avatar
have you physically checked the oil level since the drive? or are you just assuming?
Old 11-15-2006 | 06:27 PM
shoispo
I checked it and its full
Old 11-15-2006 | 08:06 PM
YeuEmMaiMai's Avatar
oil pump is dying or restricted pickup
bad sending unit
Old 11-15-2006 | 08:12 PM
brayner's Avatar
worn crankshaft and rod bearings? I'm new to Hondas, I don't know what range RPM the oil pressure gauge is active. My vw only senses from 1500-3500 RPM, turning off at idle
Old 11-15-2006 | 09:44 PM
deserthonda's Avatar
before you condemn anything you need to chk oil pressure,,,,,,,,,,remove the oil sending unit,( above oil filter) hook up a pressure gauge and see if it is in specs ,,if within specs i would start by replacing the sending unit ,,,,,,if low then you might have oil pump or ( and ) bearings issues
by the way did this start since the oil change you did a few days ago? did you use a Honda filter ??
Old 02-06-2007 | 03:58 PM
overdubbed
The same thing is happening to me... (1992 Honda Accord EX) it just started this week. I'll post a video of it on youtube when I have a chance... frustrating as hell since the car runs fine/always has been well maintained and the oil level is correct.
OP did you figure out what was going on/did were able to fix it?
Anyone have any leads w/ this?
Old 02-06-2007 | 06:07 PM
ORIGINAL: overdubbed
scroll up onereplyand read my suggestion
kayweb
06-02-2013 04:50 PM
Ryeguy
08-07-2012 09:15 PM
mvickky
07-06-2009 07:59 AM
rotaxrave
12-09-2007 01:26 PM
