This boggles my mind
Old 04-04-2006 | 08:53 PM
ERKnJERK
Default This boggles my mind
When i got my 89 Accord it ran. But the it had a power wire hooked in the batt. terminal, And caped with another power wire that ran to nothing. It needed a new battery anyway i just took out the battery out of my old chevy put it in the honda,Then i bought new terminals but i think i got the wrong ones they are little big but the head lights work. But now the car doesn't turn over no clicks or nothing. Think Anyone can help ?
Old 04-04-2006 | 09:07 PM
sir_nasty's Avatar
Default RE: This boggles my mind
Did you make sure that someone didn't reverse your wires on the old batter, I.E. Red wire running to ground black to power... also if your connections aren't secure to both your battery and your starter you could have some issues. Is the ground and Power wire connected securly with a good solid connection? Are you positive that the battery has a good charge?
Old 04-04-2006 | 10:11 PM
deserthonda's Avatar
when you put the key on do the dash lites come on >> ? oil lite, battery lite etc etc ..if not chk in the underhood fuse box for any blown main fuses,,,
if lite come on, chk to make sure all connections are clean and tight, chk to see if you get power at starter main wire, and also chk to see if you get power at starter solenoid when someone cranks the car ..
if no power at solenoid you could have a bad igniton switch,,
But do ther easy things first ,chk all the main fuses in the underhood fuse box
Old 04-04-2006 | 10:36 PM
mbo1985's Avatar
I had a situation like this once. My mechanic buddy of mine insisted I needed a new starter. The lights worked, radio came on, etc etc.
Turned out the battery just didn't have enough juice to even make the solenoid do it's thing. Wouldn't crank or anything. A brand new battery fixed it. If that battery has been sitting for a while, this could be the case. Good luck!
Old 04-06-2006 | 03:07 AM
ERKnJERK
yeah this is pretty weird i have a blown fusible link (say's it's for the battery) windows don't work lights on the dash comes on and it beeps i ordered the fuse from honda ima try new terminals (again) and a new battery i'll keep you all posted if you like
Old 04-06-2006 | 12:05 PM
accorddriverc's Avatar
ORIGINAL: ERKnJERK
yes let us know the outcome
Cinawina
12-02-2020 12:14 PM
KhmerKid94
07-03-2010 09:36 AM
00crossfire
12-06-2009 05:36 PM
mums96slpr
11-26-2007 09:59 PM
XR6R
09-25-2007 05:18 PM
