Brake ?
Old 01-16-2006 | 02:36 PM
PCKID
Default Brake ?
I have a 2004 Accord Ex that need rear brakes. This is my first time changing brakes on a Honda. Got everything off and I'm trying to push back the piston in caliper with a C clamp and it wont go. Do I need a special tool?
Old 01-16-2006 | 04:58 PM
TYTALEX's Avatar
Default RE: Brake ?
If the inner pad has a few nipples that fit into the piston it needs to the screwed into the caliper clockwise. There is a tool made for this, that could be purchased at your local shop, but you can surely fabricate something as well. You need to keep good possitive pressure on the piston while threading in. Make sure that you line up the piston with the nipples on the pad prior to assembly.
Old 01-16-2006 | 11:58 PM
deserthonda's Avatar
Default RE: Brake ?
if it is a cross piston like TYTALEX said,, get a screwdriver, put it sideways and screw in the piston , that's what i use ,,,If a straight piston, a c clamp should do the job..
Old 01-17-2006 | 08:06 AM
lightshow's Avatar
Default RE: Brake ?
yea if you see a indented line across the face of the piston, then it does need to be screwed in. COUNTERCLOCKWISE though, youll figure it out. now if it is flat piston, you may just need a better tool (like a piston compressor). now if you let the pads go way down and the piston is fully extended, it is going to be a serious bitch to push it back in. here are some pointers.
put the caliper back on and but the two bolts on just hand tight that hold it on, its an 8mm that will crack that bleeder valve. dont use the box end of a wrench or you will probably strip it, because for whatever reason, that metal is not very hard. if you do strip it, let us know i have dealt with that bull**** before. ok now after that is cracked, also crack the nut that holds the brake line on the caliper. now take the caliper completely out, and then squeeze it with that c clamp, youll notice its about 5000 times easier with the caliper removed.
let us know how it goes though i am curious
lightshow
Old 01-23-2006 | 12:33 AM
PCKID
Default RE: Brake ?
I used good positive pressure with the C clamp and it screwed in ok. The key is to have the C clamp strait and perfectly flat on the piston's head.
Thank's Folk's
Old 01-24-2006 | 12:14 AM
Default RE: Brake ?
yo Lightshow ,, i hate to do this to you pal , but i have to correct you,,,,,,,,,,you screw the piston in CLOCKWISE ,,
rudeg
12-31-2015 08:23 PM
aznofthe205
02-11-2009 07:15 PM
J2Performance
01-15-2008 05:29 PM
98accord98
09-08-2006 02:25 AM
