Brake Fluid Change Necessary?
Old 02-01-2006 | 05:42 PM
ernie22golf's Avatar
Default Brake Fluid Change Necessary?
Hello Forum Folks,
I bow to those with more knowledge than I. Do I really need to have the brake fluid changed after 3 years in a 2003 Accord with ABS? That's what the maint sch says so I'm set up to have it done but I just had never heard of this.
Thanks
Old 02-01-2006 | 09:26 PM
RTexasF's Avatar
Super Member
Default RE: Brake Fluid Change Necessary?
Yes you should. Brake fluid is hygroscopic......it absorbs moisture and does wear out over time. Folks think it's a "forever" fluid but it is not.
Old 02-01-2006 | 09:40 PM
7thGen's Avatar
That is correct. The brake fluid breaks down due to the heat that it is exposed to when you brake. Your fluid will get dark as it breaks down. If it is cloudy it has water in it. Remember that the brakes are the most important part on your car. Never neglect that system.
Old 02-01-2006 | 10:28 PM
RTexasF's Avatar
Super Member
ABS systems require clean fluid to operate properly too, they don't like contaminated fluid at all--------very expensive!
Old 02-01-2006 | 11:07 PM
Thanks
That does make me feel better. I'm really impressed with the car. Thanks for your help.
Old 02-01-2006 | 11:39 PM
RTexasF's Avatar
Super Member
Mine is due for it next year.
93Accord2.2
12-17-2021 10:59 AM
62maxx
10-18-2015 09:20 AM
tomtom
10-05-2010 07:50 AM
Tony1M
09-04-2006 09:52 PM
