Brake Pad squealing/wearing weird
So recently, my car was making scratching and screeching when I'd apply the brake at slow speeds. Over the last week they increasingly did this when I'd come to a stop. Me and my dad checked the brakes today and the driver's side brakes were pretty worn down. The inside one was almost worn down to the metal! and the outside one had a little more material. Worn about the same.
However, the passenger side ones had lots of material left on them. Is this indicative of a problem on the driver's side brake area? What should I check?
Thanks everyone for your help for this and in the past. I'd be lost without all your help.
The brake pads have metal tabs that will make a horrible screetching sound when the pads are nearly worn out. It might be as simple as worn-out pads.
Take off the wheels, open up the calipers, & take a look. If it's just worn pads, then you should still clean & lube the caliper slide pins.
Donda
05-17-2014 03:49 PM
bougie_44
05-16-2012 02:14 PM
