brake pedal switch/shifter assembly replaced but.....
Old 12-08-2010 | 06:12 PM
thadjons2007's Avatar
Question brake pedal switch/shifter assembly replaced but.....
So on my last thread my 1991 honda accord ex after a rainy night wouldnt shift out of park. So i had my mechanic replace the brake pedal switch/and shift assemby in the car but my car still gives me the "S" mode light and still only have 2nd/3rd gear. I check the numbers on my TCU and the numbers indicate that it is the modified version of the older pxo 732-733 TCU(the one in the car is a PXO 932-933). Did the mechanic have to reset the Computer after doing work? or should i start looking at the shift solenoids on the tranny?
Anyone
Old 12-08-2010 | 06:31 PM
Also the "S" light doesnt come on until i apply the brakes at a light or stop sign
Old 12-08-2010 | 08:04 PM
Did replacing the TCU get the car to shift out of park?
Did you try checking for TCU codes on this TCU?
Old 12-08-2010 | 08:10 PM
nope we replaced the brake switch and the switch thats located in the center console(interlock switch maybe?).
thinking of just bring it to honda, but whats puzzling is that the S light flickers when i first start it up then only comes on again when im at a light with the brake pedal pressed and as soon as i let the brake go it turns off.
Rabbit
09-14-2012 03:27 PM
Liquid Dwayno
04-28-2012 09:24 PM
sambonater
02-19-2011 08:24 PM
freemoney
11-19-2010 03:30 PM
19962door
05-17-2010 04:30 PM
