Brake pulse at high speed.
Old 06-21-2011 | 10:42 PM
01SilverAccord's Avatar
Thanks for the inputs guys. I finally found the problem. It's the rear brakes, they've been frozen for awhile. This is what they looked like...
They're rusted so bad to the point that the pad didn't make any contact to the rotors. The main reason they're rusted was the boots of the two bolts in caliper bracket were ripped. Water, salt and all kind of debris got in there and freeze up the bolts which prevent them moving in and out. Here they're
I had to cut off the old boots in order to remove the bolts. The replacement boot kit was $9.99 at any autopart stores. Put everything back together
After a quick ride, ALL the rotors are a little warm NOT the only front rotors. The car stops much better and no more vibrations.. I'm soooooo happy.
Old 06-22-2011 | 06:27 AM
piggylover1985's Avatar
Glad you solve the problem :-)
Old 06-24-2011 | 09:20 PM
thanks piggy
irhunter
03-23-2011 05:49 PM
XxBladesxX
02-12-2010 07:18 PM
sinister1
01-30-2008 03:34 PM
japo2336
01-09-2008 10:21 PM
jmyler
12-01-2007 11:33 AM
