brake warning light turns on when installed backup camera
Old 01-16-2021, 10:02 PM
Seanjordan20's Avatar
If you can do a factory reset try it. If it doesn't work then send it back because it's defective.
  #22
Old 01-16-2021, 10:33 PM
aplaceinthesky's Avatar
Did it with no effect. I will contact the seller. Thank you guys for the assistance
  #23
Old 01-17-2021, 11:39 PM
I connected the dash camera to a USB charger and it actually works. I did a reset and format again the sd card but when I connect to the cable in the car, it just do the same as before, so I think the problem is related to the work the mechanic did
Does anyone know where is located the fuse box? And how to access to it?
  #24
Old 01-17-2021, 11:56 PM
You should of done a reset on the device setting it back to factory. Are you saying the mirror power is coming from the accessory port?
  #25
Old 01-18-2021, 07:18 PM
it looks like it connected to the accessory port. I will go to talk with the mechanic today. I did a factory reset but with no luck
cb7lives
03-19-2012 09:56 PM
indy49
12-16-2011 09:13 PM
chillnndc
09-15-2011 07:07 AM
poolman
01-14-2009 05:44 PM
Quick Reply: brake warning light turns on when installed backup camera
