break problems
break problems
I have a 92, and this past week its been about 95 degrees everyday. the past two days I have noticed that my brakes are really soft!!! i checked the fluid, theres no leeks. What could be the problem!?!
**I moved this to the Gen Tech Help section** - LX5spd
RE: break problems
welcome!
the most likely problem is that moisture got into the brake system and lowered the boiling temperature of the lines. now when you step on the brakes the fluid heats up and "boils" creating gas in the lines, which is compressible.
bleed the brakes and you should be fine.
also, this should go in general tech help, this area is for suggestions and questions about this website.
