Bright Orange Coolant?
Old 07-01-2009 | 09:19 AM
guinnessmike's Avatar
Default Bright Orange Coolant?
I have a 89' Accord that I bought about 6 months ago. When I got it I noticed the coolant was this bright orange-rust color but the car had other problems that needed more attention. A friend told me it was prob some of that stop leak stuff. 2 months later the radiator started leaking (I know you are shocked), so I got another radiator from a yard and drained and refilled it 3 times (letting the car come to temp each time) and thought I got all of it out. Since then I have had to add about a quart of coolant two times and it is bright orange again. I can't seem to see any leak and there is no coolant in the oil. Any ideas on why the discoloration or where to look for my lost coolant?
Old 07-01-2009 | 09:28 PM
It might be a chemical reaction due to leaking head gasket allowing contamination of coolant w/ exhaust gases and loss of coolant. There is a chemical test available to detect exhaust gases and gasoline in coolant. Try the test.
Other symptoms of leaking head gasket are engine missing on a warm re-start, steam (white smoke) vapor in summertime, possible oil contamination (yellow-white scum on dipstick and valve train), and overheating and bubbles in overllow tank.
Old 07-02-2009 | 02:50 PM
I have no other symptoms of a leaking head gasket (thank goodness). I will probably try that chemical test though. Do you have any idea where to get it or what it is called exactly?
Old 07-02-2009 | 03:56 PM
deserthonda's Avatar
could be a very rusty block...........have a shop do a full coolant flush using using the machine
as for losing coolant,, have them pressure test the system before doing a flush
AUTO Design
11
12-22-2011 12:31 PM
Codycancatch8
07-04-2011 10:45 AM
dre707
05-18-2010 06:52 PM
Smudgie
09-02-2009 07:35 AM
accord5g
08-23-2006 08:39 PM
