broken lug bolt
broken lug bolt
so i got my tires swapped around but one of the lug nuts was siezed pretty good and i ended up snapping it off. i was wondering how difficult it will be to remove the broken lug bolt and get the new one in and if i'll need any special tools. i'm getting ready to call around to find the part.
bummer doods
think it's ok to drive around like that for a short amount of time. it's the front passender side wheel.
bummer doods
RE: broken lug bolt
If it's a V6 with 5 lugs, you're fine with 4. If you have 3 left of 4, you are ok for a bit, but should be a little concerned with leaving it that way. Basically, you have to remove the hub, press out the old stud and press in a new one .... if you don't have access to a press, you need to have it done for you.
Tommy997
07-26-2006 02:14 PM
