Bumper turn signals is not working.
Hi. How do you fix the bumper signal lights. both of them are not working and causing my turn signal to blink very fast.
I look at it and it seem fine with the wire...
Need helps.. thanks......
RE: Bumper turn signals is not working.
Have you tried replacing the bulb? typically when they start blinking fast it's just a bulb or a fuse problem (providing the wiring is ok) or just pull out the bulb holder and turn the signal on and put a tester in there to check for power, if no power then check your fuses
