burning too much motor oil
Old 09-15-2008 | 06:13 PM
bambooyou's Avatar
Default burning too much motor oil
My accord seems like burning too much motoroil. Its a 2000 accord lx, 4cyl, auto with 86000 miles. I change the oil one month ago. At that time i check the dip stick the oil level was little above the top hole. Today,after 1000 miles,i check again it only has about 1/8 of an inch at the tip of the dip stick.I don't find any oil leak stain on the ground. Can some honda fan tell me where to check for the problem? Thanks for anyone who can help out.
2000 accord lx , 4cyl , auto
Old 09-15-2008 | 06:16 PM
Default RE: burning too much motor oil
first thing to consider is if you check your oil while the car is on a slope, it will effect the reading.
next, have someone follow you and have them watch for blue smoke.
if there is blue smoke then compression and leak down tests are in order
Old 09-15-2008 | 08:03 PM
19Accord97
Also make sure to check your oil levels when your car is cold or has been sitting overnight.
Old 09-15-2008 | 10:07 PM
Inspect the intake duct downstream of PCV air outlet. If it's coated w/ oil and grime, the PCV is allowing too much oil vapor to be pushed into the inlet. Check the PCV valve (should rattle and check air flow in one direction) and PCV hose (clear of any blockage).
If PCV is working OK, that leaves two possibilites; valve stem seals or worn engine (excessive oil bypassing rings).
Old 09-16-2008 | 10:25 AM
08coupex's Avatar
You could be burning it. Or check your anti-freeze and see if its really dirty. It could be leaking into it meaning you have a head gasket leak or intake manifold leak.
Old 09-16-2008 | 11:10 AM
falkore24's Avatar
Most common leak point is the drain plug. You said that there's no puddle, but you might have just not noticed it. If the crush washer isn't changed when changing the oil, it can leak very easily.
Old 09-16-2008 | 12:59 PM
patrickz's Avatar
"burning too much oil" i dont think burning a little oil is good in the first place. lol check ur gaskets.
RobinsonRicer
12-22-2013 09:42 AM
Sadus
09-07-2011 12:29 AM
NICK63
11-02-2009 12:57 PM
kevinlurks
12-19-2007 12:05 PM
joninja
12-01-2007 01:13 PM
