buzzing noise
Old 12-31-2011 | 01:30 AM
firerest6's Avatar
Default buzzing noise
HI EVERYONE AND WISH YOU ALL A HAPPY NEW YEAR!!!! I HAVE A HONDA ACCORD EX 1994. MY BRAKE AND ABS LIGHTS ARE ON. WHEN I FIRST START UP THE CAR IT MAKES THIS BUZZING NOISE. IT HAPPENS FOR MAYBE 3- SECONDS AND THEN HAPPENS AGAIN AND AGAIN FOR 5 OR 10 MINUTES . AFTER THAT IT STOPS. THE CAR RUNS GREAT. DOES ANYONE HAVE AN IDEA WHAT THIS CAN BE? THANKS FOR ANY HELP YOU CAN GIVE ME. DAVE B. FIREREST6.
Old 12-31-2011 | 09:34 AM
A few things. Check the brake fluid in both the brake master and the abs unit.
You can get the codes for the ABS, see the Common DIY Threads sticky at the top of this section. Sounds like a "pump over run"....but need to check the fluid and then get the code.
Old 12-31-2011 | 05:08 PM
accordlover's Avatar
I had the same problem with my 95 accord. It ended up being the abs unit was bad. But like poorman said check the fluid first if it is low it will make that noise.
Old 09-06-2020 | 11:26 PM
candi117's Avatar
I have a 94 accord doing this exact thing and my ABS light is on however I also have a 1999 civic doing the same thing but no lights are on. hmm
anyway I've heard you can get the code for these year models by sticking a smile paper clip and entity OBD connector. Are you absolutely positive this isn't Are you absolutely positive this isn't going to "light me up"??
it just kind of feels like that time my brother said "just lift up the fence wire and come through,it won't shock you, I swear! Just quit being a baby and come on through or go home!" 🤨 Dude,
I should've just went home🥴
Old 09-06-2020 | 11:59 PM
Find the blue 2-pin service connector under the glove box near the glove box hinge. It will be plugged into a connector with no wires, so a dummy connector. Jump the two pins with a paperclip, turn the key to the II position, then count the abs light flashes.
If you are concerned, post a picture of the connector you want to short and we will verify it is the correct connector.
cruzjnr1
04-06-2013 03:23 PM
morenaje809
03-18-2013 09:51 PM
andy 95
07-16-2011 02:48 AM
hondajuice
01-14-2010 07:30 PM
Drpepper
05-27-2007 08:36 AM
