A/C compressor cycling
Old 04-08-2008 | 04:50 PM
SteveZ's Avatar
Default A/C compressor cycling
Compressor keeps cycling on and off. Checked and system appears charged. Checked with gauge that comes on can of 134. It's a 92 accord and I had it converted three years ago. Any suggestions
Old 04-08-2008 | 05:22 PM
turbodave's Avatar
Default RE: A/C compressor cycling
On/off cycling is normal on most all compressors. Unless it's happening way too fast. What are the cycle times?
Old 04-08-2008 | 09:07 PM
SteveZ's Avatar
It will run for about ten seconds then shut off for about twenty seconds.
Old 04-08-2008 | 09:52 PM
Chiovnidca's Avatar
ORIGINAL: SteveZ
That's a little too much. Has it had any a/c work done recently? Are both the cooling fans running?
Old 04-09-2008 | 07:35 AM
SteveZ's Avatar
Both cooling fans run when compressor kicks on. Only work done was three years ago I had it converted to R134.
Old 04-09-2008 | 10:46 AM
deserthonda's Avatar
ORIGINAL: SteveZ
what is the ambient temperature ??? if it is cool outside the compressor will run for a very short time,, but still ,,it should be off a bit more than 20 seconds
Old 04-09-2008 | 12:47 PM
Fast cycling can be from being over-charged, right? How was the skill-level of the shop that did the conversion?
Did they manage to remove all the old oil? Compressor oil for R-12 isn't compatible with the R-134a.
Did they know the amount to charge? I think R-134a wants to use less refrigerant. Also charges to different pressures?
Old 04-09-2008 | 03:40 PM
SteveZ's Avatar
The ambient temp was about 55 degrees. I thought this might have something to do with it. The guy that did the conversion is experienced and it has worked fine. It is still working fine it's just that I noticed the compressor cycling alot. I guess your right maybe the quick cycling has to do with the outside temp being on the cool side. Thanks to everyone for their help
redbull-1
01-07-2015 10:37 AM
Jug
10-15-2012 07:04 PM
antoniogamu
08-30-2011 06:53 AM
jeffradja
05-01-2011 08:25 PM
Mac97AccordLE4cyl
03-14-2011 07:34 PM
