a/c compressor won't engage
Old 05-15-2005 | 01:49 PM
accordn2me
Default a/c compressor won't engage
I have a '96 that I just bought, a/c blows warm, figured it needed a charge & hooked up a can to low side- no suction at all, jumped pressure switch & fans came on but compressor does not seem to be engaging. I've checked the fuses under the hood and dash- both good. How can I tell if i've got a bad comp?
Old 05-17-2005 | 10:22 PM
Burn69's Avatar
Default RE: a/c compressor won't engage
Use a pressure tester to see if there is any leaks in it
Old 05-19-2005 | 12:00 AM
Evlampius's Avatar
ORIGINAL: accordn2me
first of all - have you read my post about the trick for 94-97 A/C cooling??
second why did you jump the pressure switch? thats not exactly how you test the compressor -
I can tell you how to check it ... please post if interested , I see that you havn't post anyother post , so I don't know if you're still interested
Old 05-20-2005 | 11:19 AM
accordn2me
I read your post about the cable, but that works fine. The problem is that the comp does not engage at all. There is refrigerant in the system still, but I can't get an accurate reading without the comp engaged. I jumped the pressure switch in an attempt to get the comp going to accept a charge. That has worked beautifully on every other vehicle I've tried it on but not this time.
If you can tell me how to test it I'd appreciate it.
Old 05-24-2005 | 08:48 PM
accordn2me
bump^
Old 05-25-2005 | 12:29 AM
Evlampius's Avatar
by the problem you describe it sounds like you need new compressor ... I have to double check something give me some time
Old 05-25-2005 | 12:18 PM
accordn2me
OK, thanks...
Old 05-25-2005 | 04:00 PM
1s
can you link me to that post because i'm considering buying a '97? thanks!
7coupe9
11-25-2022 10:50 PM
tonrod
04-21-2013 06:00 AM
Rice
04-27-2012 08:38 AM
PitViper42
07-06-2010 11:09 AM
aneelley
04-19-2010 07:40 PM
Quick Reply: a/c compressor won't engage
