A/C Dead 1993 Accord - Help Please
Old 05-30-2013, 07:20 PM
Yes, gauge can be zero'd. Be sure you have no trapped pressure in manifold. I assume you mean 35 psi rather than 350 psi?
Old 05-31-2013, 09:40 AM
scoostraw's Avatar
That wasn't a typo. It reads 350. (The photo I posted was taken with the gauges hooked up to the A/C)
I don't think there is any trapped pressure. I am able to move the needle with the screw in both directions, but it is so far off that I'm unable to reach 'zero' from either direction. I may take the back off the gauge and see if I can do anything from there?
  #33
Old 05-31-2013, 11:39 AM
From your description, the dial would have to go down from "0-pressure" position to reach what was in your photo. This should not be possible w/ a bourdon tube gauge. Something is "out-of-whack" in the gauge mechanical movement.
OTOH, perhaps the adjustment has enough range to rotate CCW to 350 psi position?
Old 05-31-2013, 06:56 PM
scoostraw's Avatar
I think I'm describing it wrong.
At rest, the gauge reads 350psi. When I hooked it up to the system, the needle moved from there clockwise thru 500 and past zero - and ended up at 75psi.
The zero-adjust screw does not have enough range to get it to zero. I took the back off and can see nothing amiss. I have no idea what happened to it.
However one could interpolate the reading in my photo to be about 275psi. It was about 85 degrees that day and very humid. If that a bit too high for the high side?
(I plan to contact Uniweld about a replacement gauge)
<EDIT> Look what I found on eBay:
http://www.ebay.com/itm/160948945673?ssPageName=STRK:MEWNX:IT&_trksid=p398 4.m1439.l2649
  #35
Old 06-09-2013, 09:42 AM
scoostraw's Avatar
My replacement manifold gauge arrived, and I instinctively was going to use teflon tape on the threads. but then I hesitated.
Doing some googling I found mention of using blue loctite on the threads. Do you guys have any thoughts on what I should use?
blubaustin
08-19-2012 12:04 PM
Lenno
01-29-2012 07:45 PM
Pizzle_00
12-22-2011 05:15 PM
ohill1981
06-16-2011 11:48 PM
3accords
08-26-2010 12:22 PM
Quick Reply: A/C Dead 1993 Accord - Help Please
