A/C and Heater Controls
Old 01-17-2012 | 04:51 PM
WI2003Accord's Avatar
Exclamation A/C and Heater Controls
Hello,
Yesterday my 2003 Honda Accord EX-L, 4 Cylinder started having these problems:
None of the A/C, Heater, Rear Defroster buttons light up or work. (Radio still works and lights up)
Nothing blows out of the vents.
Heated Seats don't work.
Rear Defroster doesn't work.
Temperature gauge on front dash doesn't give temperature, it just reads ---. (I can still see the odometer reading and miles in current trip so lights are working)
I checked the fuses and none of them are blown.
Has anyone seen this type of issue before?
Thanks
Old 01-17-2012 | 09:36 PM
Double check the owners manual, there are at least three (I really think there are four but) fuse panels on these.
Any recent work done....battery replaced, ect ?
Old 01-18-2012 | 10:01 AM
Exclamation
Hi,
Thanks for your reply. I do have the owner's manual and it only lists 2 fuse boxes. One under the hood and one on the drivers side by the hood release. I know the heated seats have a seperate fuse then the Rear Defroster and the Fan is on a seprate one also so I was thinking it wasn't a fuse issue. But I did check them and none of them are blown.
I had the battery replaced last winter and no other major repairs have been done to it. I had a sensor go bad 2 or 3 years ago and that's about it. I do have a non-factory remote start in it which was installed over 3 years ago but that is working as well. Do you think this could still be a battery issue? I do have 150,000 miles on it but mostly they are highway miles for work.
Thanks
Old 01-19-2012 | 06:54 PM
Sorry, don't have a good manual for the '03s yet. The one I do have lists the #30 7.5amp as the one for the HVAC and the Defog....heated mirrors....power mirrors.
Old 01-19-2012 | 08:27 PM
It sounds like the HVAC panel is bad on your car.
In the common DIY thread on top of the gen tech help forum, there is a link to checking HVAC codes for 7th gen accords. Also, there is a link in the online shop manual thread for a shop manual for 7th gen accords.
j894
02-08-2014 07:41 PM
Dan Fulmer
11-06-2011 01:34 PM
stigmahisen
09-26-2007 12:20 AM
mdjbhouse
01-04-2007 09:33 PM
