Cabin Air Filter, How Do I Change It????
Old 07-24-2006 | 07:21 PM
joe592's Avatar
Default Cabin Air Filter, How Do I Change It????
2000 Accord 4dr LX. I want to change my cabin air filter. I know it's behind the glove box but what exactly do I need todo to get it out?? Hows the glovebox come out? Thanks, Joe.
Old 07-24-2006 | 10:15 PM
YeuEmMaiMai's Avatar
Default RE: Cabin Air Filter, How Do I Change It????
you have to remove glove box and support bar. once you do that, remove clips holding plastic case together. after that, remove both filters and use a shop vac to clean up the mess.
here are the exact instructions
http://www.micronair.us/assets/pdfs/89.pdf
Old 07-25-2006 | 12:05 AM
locovaca's Avatar
The support bar really sucked in my car. The screws were really way too tight and even with an appropriately sized screw driver I about stripped both. I eventually took a pair of vice grips and loosened 'em up that way.
Old 07-25-2006 | 12:23 AM
Chiovnidca's Avatar
ORIGINAL: locovaca
Yep, i've broken many a phillips bits on those.
Old 07-25-2006 | 05:01 AM
deserthonda's Avatar
Joe,if you would have searched,, there is a write up on our DIY section with pictures and instructions
How to replace cabin air filter .....
Special_K
08-12-2011 05:16 PM
stonesfan
03-08-2011 08:44 AM
ccasey3655
07-07-2010 09:02 PM
deserthonda
06-21-2006 06:22 AM
alabamatoy
01-24-2006 11:17 PM
