Cam position sensor
#42
Did you try getting the car to coast in neutral, then pop the clutch while in gear?
I am just wondering if the first signal generated by the new CPS may allow the ECU to know when it needs to send spark and fuel to each cylinder.
#44
I just noticed the fuel pump isn't priming when I have the key in position 2. I checked the fuel pump fuse in the car, looks fine. I'm not sure if that would cause the lights not to appear or maybe since the lights wont appear the fuel pump is not receiving a signal.
