Camber 1 degree out 98 Accord
Old 01-08-2007 | 08:08 AM
Smokey
Default Camber 1 degree out 98 Accord
Hi Guys
A while ago i posted regarding wear on the outside of the near side rear tyre. The alignmet had been checked but as most of the replys suggested that, i whent some where else. This time i was able to watch what was beeing done and talk to them while they were doing it. So it turns out that the wheel is 1 degree offcamber causing thepull to the left and tyre wear. They tried to adjust this out but were unable to improve it. They have suggested that something is bent. So my question now is what bits do i start to replace and what sort of money am i looking at.Are second hand parts a viable option?? The car has just clocked one hundred thousand miles at this point and has been perfect until now.
Any guidance will be greatly appreciated. Steve
Old 01-08-2007 | 09:54 PM
hondadude's Avatar
Default RE: Camber 1 degree out 98 Accord
Is the camber negative or positive?
Old 01-09-2007 | 07:48 AM
Smokey
Hi HondaDude,, Not sure if they mentioned which one. If there is no adjustment on the camber and the camber is out would it leave any option other than to change parts??
Old 01-09-2007 | 03:08 PM
sir_nasty's Avatar
Knowing if it's a pos. or neg. camber would probably give him a better idea of what parts to check. Do you have a stock suspension and rims/tires?
Old 01-09-2007 | 11:20 PM
hondadude's Avatar
Best I could do at this point; went snooping around 'Oreilly Auto parts website.
'MOOG' rear camber link kit P/N K90204 Fits 98 accord LX 4 door; allows for adjustments of negative 1.5 degree thru positive 3 degree.
Call around the local parts houses and ask for the REAR CAMBER LINK kit made by MOOG.
Old 01-10-2007 | 08:54 AM
Smokey
Sir nasty, the whole car is stock. Would this camber problem account for the pull to the left as well?? I might be getting paranoid but the steering feels funny and the steering wheel will turn to the left when moving forward at 1-2 mph. Also i have noticed that when on full left lock in reverse the steering does not try to return to center just stays full lock. Is that normal??
Honda dude. I'll start checking around now.
Thanks for your help so far guys.
Old 01-10-2007 | 12:29 PM
deserthonda's Avatar
outside wear on a tire is positive camber,,,,top of tire tilting outward causing wear on outside threads . Also as you say if it is the rear tire it should not affect a pull as much as you say.
are all the tires ok ??
to reposition camber to specs you do have to replace componets or as Dude suggested and a cheaper way, install a camber kit on the rear but i stil feel you got some other issues with the frt end
post the alignment results here if you have them let me read them
and 1 more thing,, on our DIY section there is a write up on understanding alignment.. take a look and read up on it
Old 05-02-2007 | 02:01 PM
mamarotta's Avatar
its the ball joints...all they have to be is alitbit
tlhfirelion
02-07-2013 07:16 PM
19Accord97
03-24-2009 08:11 PM
sd_hog
03-20-2008 07:47 AM
19accord95
02-11-2006 03:06 AM
