Can faulty PCM Cause Transmission failure?
Old 05-18-2009 | 04:10 AM
ufosearch's Avatar
Post Can faulty PCM Cause Transmission failure?
Hey fellow techs, I had a question about my 97 honda accord. Few months ago my original transmission took a dump, I retrieved a PO740 code. The transmission was toast, the local trusted tranny shop diagnosed it with a pump failure, probably because the tranny filter is inside unit and not easily serviceable. I simply located a new low mileage tranny and worked great at first, then i got the 740 code driving home on the highway no troubles, then next day or two it started slipping badly until it finally was toast also. I am on my second replacement unit. Heres where my question comes into play. I found a TSB concerning code PO740 and depending on VSS speed indicated either faulty PCM or remanufactured tranny. If my PCM is bad, could it cause my transmission to prematurely fail?
If anyone could help clear this up for me?
Thanks in advance!
-Scott
97 accord 192k miles
mamtsberg
09-10-2012 09:58 AM
brianwindorski
10-11-2011 12:33 AM
cypherdtraitor
07-16-2011 03:24 PM
toicy4ya
08-02-2008 12:21 PM
blazedg
07-05-2005 08:52 PM
