Can this H22 engine go into my 93 Accord Lx
Im thinking of swaping a h22 engine into my 93 Accord Lx. but dont know what im gonna need for the swap. Can I sawp the engine below to my accord?
Below is what comes with the engine. Is there anything else that i would need other than whats listed?
H22A Type S DOHC VTEC SPECS:
Donor Vehicle: 97-01 JDM Honda Prelude Type S
Mileage: 15k-30k miles
Engine Code: H22A
Valvetrain: DOHC VTEC, 16 Valve
Displacement: 2157cc
Horsepower: 223 HP @ 6800 RPM
Torque: 163 LBS-FT @ 5500 RPM
Compression: 11.0:1
Bore: 87mm
Stroke: 90.7 mm mm
OBD: 2
Redline: 7200RPM
INCLUDED PARTS:
100% Complete Engine
- Complete Block
- Complete Head
- Intake Manifold
- Engine Wiring Harness
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- Intermediate Shaft
- A/C Compressor
- Power Steering Pump
5 SPD HYDRAULIC LSD TRANSMISSION
- With clutch and flywheel assembled to the engine.
- Honda factory Limited Differential is inside the transmission
OBD-2 VTEC ECU
Engine Code: H22A
Compression: 11.0:1
Bore: 87mm
Stroke: 90.7 mm mm
OBD: 2
Redline: 7200RPM
INCLUDED PARTS:
- Complete Block
- Complete Head
- Intake Manifold
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor
OBD-2 VTEC ECU
marbro
05-12-2006 05:29 AM
