Can I use Prestone Engine coolant for my Accord?
Honda fluid is blue, but so is several other fluids. Still, if it was a CPO car it's a safe bet that was Honda fluid.
If you've never had overheating problems; never had reason to suspect crud/scale buildup in the cooling system, then drain & fill with premixed coolant sounds good.
I had a 98 Accord 4-cyl & when I have drained it, including the block drain, I needed more like 6 or 7 quarts to refill. So I expect you'll need to buy a 2nd gallon.
Accord cooland drain and fill
I just did the radiator drain and fill on my 09 Accord. That is the radiator and the coolant overflow container too. It took a little more than a galllon.
The Honda coolant certainly costs more than the Prestone, but if you want to switch coolants entirely you would might go through 3 jugs of the Prestone, bringing the costs of Prestone to about the same as the Honda type II. I think its just easier to drain and fill and not worry about flushing the entire system out. I'm guessing that a drain and fill once/year should do better than flushing out the entire system every 4 or 5 years. I also suspect that the Honda coolant is superior than Prestone.
Vic
Vic
Vic
xaznxeclipsex
09-28-2007 03:05 PM
jrcastro
06-24-2006 01:45 AM
