Can I used 5W20 instead of 5W30?
Old 04-10-2013 | 11:07 AM
JonJon13926's Avatar
Default Can I used 5W20 instead of 5W30?
I know it's just a difference in viscosity, that the 20 has the lower viscosity, and I also know it's Spring and getting pretty warm, but I paid $40 for a 5 quart jug of full synthetic and I threw the receipt away. Lol.
Old 04-10-2013 | 11:09 AM
Dr. Drivability's Avatar
should be fine, the next generation accords call for that anyway...mostly due to tight engine tolerances and increased fuel economy.
Old 04-10-2013 | 11:12 AM
Thanks! Changing it today.
Old 04-16-2013 | 03:57 PM
Okay, so I'm noticing that a very slight amount of oil is leaking from the oil plug. I can't get it to completely stop. I tightened the plug as much as I could with my 3/8" ratchet, but it still does it (just not AS much). To give you an idea of how much it leaks, it takes hours for two little drops to come out.
What could cause this?
Old 04-16-2013 | 04:27 PM
brian74d's Avatar
When's the last time that you changed the drain plug washer? I have had a couple of cars that the drain plug washer gets old and the slightest bit deformed and I get exactly what you are getting now.
Old 04-16-2013 | 04:36 PM
Well, I don't know when it was changed last, because I just got the car a couple of weeks ago. It wasn't leaking before I changed the oil, that's for sure.
I didn't change the washer. Maybe I should do that.
Old 04-16-2013 | 05:06 PM
99% of the time that's the problem...
Old 04-16-2013 | 05:12 PM
I'll go home tonight and lay something under the oil pan and see if it's still leaking. If so, I'll order a new washer or drain plug, whichever. I can't remember if the washer comes off of this one or not, but a new drain plug with washer is only $5.
Old 04-16-2013 | 06:08 PM
EXV6NIGHTHAWK's Avatar
You can buy just the washer at a parts store. Check an online parts store website, to see what they have. I know some places have plastic or gasket material washers, so I would ask for the OEM style, which I think is soft aluminum. Don't try to screw the drain bolt in too tight, or you could strip the threads in the pan.
Old 04-16-2013 | 06:19 PM
Will do. And I don't think I put it on too tight. It was a short 3/8" drive ratchet at an awkward angle because I didn't jack the car up. Unless I don't know my own strength, it should be alright.
