cant find proper procedure to clean egr passages on v6
hi folks,
I got a 3.0L 2004 accord that is displaying the symptoms of clogged egr passages. (hesitating under load etc...) My problem is I can't find the proper procedure to do this on a 2004 3.0L. Can anyone here shed some light on this???? I've looked on this forum and others but because I'm not too computer savvy Ive come up with zilch....Thanks in advance guys.
This is the pdf for 98-02 V6 accords.
tegger.com/hondafaq/tsb/accord/A99-085.pdf
The manifold for your 04 accord in the picture below should have a similar setup. The hole in the gasket below #8 should be for the EGR port.
All you need to do is remove the intake manifold upper cover.
Remove the intake manifold upper cover (#4) and clean the intake manifold EGR port with carburetor cleaner and a brush.
The upper cover mounting bolts and nuts should be removed sequentially. After cleaning, install a new gasket (#6) and tighten the bolts and nuts sequentially. (Torque: 8.7 lbf-ft.)
Generally, the plenum does not need to come off and do any additional cleaning. Are you experiencing drivability problems or get a trouble code?
Changing the PCV valve is always good.
Anse
06-06-2009 05:09 PM
