cant put car into gear !!
Old 05-28-2008 | 03:56 PM
pnoiremix7o7
Default cant put car into gear !!
idk whats wrong..i have an 98 4dr accord V6automatic and i cant get out of park. i can start the car, i pushed the down the brake pedal all the way down while it was running to put it into drive but it wouldnt move. i read the haynes manual and it said something about the locking solenoid. am i on the right track on solving this problem??
Old 05-28-2008 | 07:52 PM
finch13's Avatar
Default RE: cant put car into gear !!
You certainly could be. When you press the brake pedal you should hear a click near the shift lever. If you don't it could mean the solenoid failed or the brake switch on the pedal, but I don't think you would have brake lights either.
Old 05-29-2008 | 02:52 PM
pnoiremix7o7
ok ill go check that out. i appreciate your help man. thanks !!
Old 05-31-2008 | 04:13 AM
4wsx099
I blew one of my fuse while trying to change the clock light and experienced the same issue... cant shift gear... So check your fuse box!
Old 06-16-2008 | 04:25 PM
pnoiremix7o7
yea it turned out to be a blown out fuse !! im happy that was the onli thing wrong but damn .. one little fuse can really mess u up. appreciate everyones help. thank you !!
letsclique
06-18-2016 05:29 PM
malachi_mez
09-15-2010 08:59 PM
ullfindsmit
01-17-2010 10:11 AM
MrGmo
05-30-2008 11:18 AM
