car attenna and car fan.
Old 01-24-2010 | 08:47 PM
imam's Avatar
Default car attenna and car fan.
hi im new to this forum. i already posted in the new section.
Anyways, i have a 1994 honda accord Lx and im having trounble with the attenna and the raidiator fan.
the problem with the attena is that when u turn on or shut off the car, the attenna makes a pretty loud creaking noise as it goes up. Would this be an electrical problem? or a simple motor problem that needs to be replaced?
And about the fan, whenever i shut the car off. the radiator fan will turn on randomly once the car is completely off and continue to run for about 3-5mins.
Thanks
Old 01-25-2010 | 09:27 AM
Loud antenna motor is probably a mechanical problem in the motor. If you're good with small stuff, the motorized antenna assembly can be removed & dismantled.
Fan running after you turn off the car is normal for Accords up to 1997. I don't know where you're located, but if it's wintertime, then maybe your thermostat is making the engine run a bit hot. If you're down under (summertime in January) then it's good.
Old 01-25-2010 | 02:34 PM
imam's Avatar
ok cool thanks so with the attenna motor all i need to do is dismantle it and look for the broken piece or something?
Old 01-25-2010 | 02:37 PM
imam's Avatar
and i live in southern california
CDJDM07
08-24-2011 10:51 AM
BOBBY-25
06-05-2011 03:40 PM
ramachan9
07-12-2009 12:57 AM
Equalizer
02-20-2007 09:57 PM
daddy
02-06-2006 03:52 AM
