Car Ramps
Old 05-06-2007 | 10:47 PM
jackkpts's Avatar
Default Car Ramps
I just changed the oil in my daughters 1992 Camry and used some car ramps a friend gave me. So much easer than using a jack and stands. I cannot use these ramps on my 2006 Accord as it hits the ramp about 3/4s of the way up. Has anyone found ramps that work well with the newer Accords? Thanks....Jack K
Old 05-06-2007 | 11:24 PM
Deleted User
Default [Deleted]
[Deleted by Admins]
Old 05-07-2007 | 02:55 AM
Cobey's Avatar
Default RE: Car Ramps
Cheat - block the rear wheels, jack the car up, slide the ramps under the wheels, and then let the car down onto them.
Old 05-11-2007 | 11:09 PM
peter4jc's Avatar
The ramps I've used w/ my '89, '92, and '94 Accords wouldn't work w/ my '98. Same problem as OP; bottom of bumper hits the ramp before tires do.
This worked for me; I cut a 2' length of 2 X 8 wood, and put that down in front of the ramps. Now the tires ride up on the wood, giving enough clearance so the bottom of bumer doesn't scrape the ramps.
Old 05-12-2007 | 09:19 AM
I've got a pair of ramps that came with these plastic wedges that extend the slope way back. It makes them about 50% longer, and theybarelyclear the front of my cars. I think it was a way to keep selling the same old steel ramps now that all cars have lower front lips.
Old 05-12-2007 | 09:34 AM
darylnj
rhino ramps work on my g35, i'm sure it's lower.
i got them at pep boys inexpensive too.
HondaPete14
02-15-2012 06:34 PM
njmodi
12-16-2011 11:06 PM
atom1
01-19-2010 04:58 PM
y9pema
09-16-2007 05:02 AM
junyea
07-26-2007 04:12 PM
