car reving by itself?!?!?!?!
Sup all. I just bought a used 1995 two door accord ex coupe 5 speed. Had it inspected for any issues just recently. Now there is one problem that I am having and its that when the car is sitting in idle while sitting at a traffic stop, it would rev by itself! It would go from 1000 rpm to 2000 rpm ever so slowly everytime. The car has an aftermarket exhaust so the reving noise is definitely noticeable. Does anyone know how tofix this?
RE: car reving by itself?!?!?!?!
Is the check engine light on at all? There is a link in the DIY section for ACC 5th gen accords that has a link to a page with the procedure to retrieve error codes.
Is the idle always at 1000 rpms, because it should be at 750 rpms. You most likely have a vacuum leak in the intake allowing more air into the system. Typically people have problems with the fast idle thermo valve (FITV) or the idle air control valve (IAC).
Take off the intake hose going to the throttle body. Before the throttle plate, there will be two holes that allow air to bypass a closed throttle plate. When the car is at normal operating temp, cover both of those holes with your fingers. The engine should stall. The lower hole should have very little vacuum when the car is warmed up.
If it still runs, then air is getting in some other way. Clean both sides of the throttle plate with throttle body cleaner and a toothbrush to make sure the throttle plate isn't stuck slightly open. Make sure that there is some slack in the cable going to the throttle body as well.
One other simple test to try is to pull the 7.5 amp radio fuse for 30 seconds. This resets the ECU so it can relearn the idle.
embagel
11-11-2010 05:29 PM
yousef
04-22-2009 11:40 PM
