Car Turns over, Has spark, and Fuel pressure at fuel rail, BUT NO START
Something I should have said from the start is that this vehicle had been sitting in a guys garage since 2005, and he said he drove it into the garage.
Ouch....now if it was running when it was last parked.....sounds like the rings are frozen.
Sorry didn't re-read everything but you are sure the t-belt is still on _cam moves/dist rotor spins/or pull the upper cover.
Roader... You are the Man! for sharing that link with me... I went threw all the post... Finally decided to check the timing marks, then removed the Valve covers turned over the motor and quickly saw that a few of the valves were not coming back up... I thought for a while, and then the next morning went out and checked it and the valves had come back up... turned engine over, and the appeared to be stuck again... So, I got some penetrating lubricant and started spraying threw the springs and using a rubber Mallet started tapping on the top of the rockers until the valves would come back up... Then I would spray again and go through the whole process again... Eventually the did not stay stuck down....
Anyway... Now the engine starts runs GREAT... no problems ... No clattering... No smoking... Awesome car... Absolutely worth what I paid for it... ;p... a friend actually GAVE me the car.... What a WIN!..... Winning!
Wudman
12-21-2012 06:36 PM
fastdart360
01-25-2008 09:19 AM
