car will not run
car will not run
i'm new to honda's. i'm trying to get the girlfriends 1988 accord. 2.0, 5 sp. carbed to run. it died while she was driving. up and quit. not getting fuel. filters are good. fuel pump relay is new honda part. no power to the fuel pump. all fuses are good. really could use some help. i'm thinking ecu. thanks. 1988 accord, 2.0 carburated 5 sp
There is a 86-89 Accord Manual for download from this site. It should be helpful.
From your description, you either have a wiring fault or damaged connector at the fuel pump. Be sure you check fuses under the dash also. This is where the manual will guide you. I would also confirm power to the fuel relay. If you have power there, the relay is bad or damaged relay connector.
Super Eurobeat
05-07-2008 11:53 AM
