cd5
Old 10-10-2009 | 04:28 AM
projectcd5
Default cd5
i gotta 94 honda accord coupe ex f22b1 so it runs good but its blowing white smoke i replaced the headgasket and intake manifold gasket there is a tiny leak coming from the back of the motor the oil is not milky brown or nothing i drove the car what else can it be iam let the car run and let the old gas out and put 91 in and see if that takes the white smoke away or can it be cause i didnt tightn the head bolts tight enough iam goin to get trq wrench tomarrow to check that please help
Old 10-10-2009 | 12:54 PM
o CRA5H o's Avatar
is it all white smoke or does the smoke have a blue-ish tint to it?
Old 10-10-2009 | 01:37 PM
Exclamation Hello Member
If you dont have a torque wrench, you can rent one at AutoZone...they can also give you the torq specs and how to do it also..thats if your not familiar with the procedure..
Old 10-10-2009 | 03:33 PM
projectcd5
i jus got one am try it now n run the old gas out n put 91 in and see wat happens
Old 10-12-2009 | 07:55 AM
I think you should get that headgasket tightened down properly before you even start the engine.
jamrock
11-07-2008 10:20 PM
UntitiledCD
07-24-2008 08:48 AM
kr95
03-25-2008 08:13 PM
ejd715
01-23-2008 11:34 PM
stratijikal
07-29-2006 04:31 AM
