CEL and code P0441
CEL and code P0441
97 accord V6. 165,000 miles. Check engine light came on over the weekend. Code P0441 92 EVAP Emission Control System Improper Purge Flow. Any suggestions as to where to start looking? Hond aplace wants $70 an hour to troubleshoot but I figured that someone here might get me going in the right direction.
Thanks
Thanks
RE: CEL and code P0441
ORIGINAL: rdrx7
Thanks
Thanks
there is a valve mounted on your evap canister( evap purge control solenoid valve...that mostlikely went bad..it takes about 30 min to replace and i have no idea how much it cost...pry OEM about 160 bucks napa or aftermarket pry about 80? could be wrong..
I am going to check all the hoses in and around the canister and EGR valve for cracks or anything this evening. It does recode if I clear the ECU. Has new gas cap within last week. I will post what I find tomorrow about the hoses and go from there.\
Thanks for the help
Thanks for the help
alright here is the update. took it to the Honda place and they checked out the expansion valve at the canister and it is good. Checked all the vacuum hoses in and around that area leading from the canister, etc. all are good and not clogged. Also when I reset the ecu and then when the light comes back on it seems like the engine loses power or misses. It is weird. Any other thoughts, suggestions, comments, anything? Thanks
this is 1 that you might have to take to a dealer or a shop that specializes on Hondas
it could bew a # of things ......you need to diagnose step by step to locate the problem
could be the EVAP PURGE FLOW SWITCH,,,,,,PURGE CONTROL SOLENOID VALVE....An open or short in the wiring between PURGE CONTROL SOLENOID VALVE and the MAIN RELAY or even the ECM itself ..
