CEL / TCS lights on, then off for a while, then on, etc.
Old 07-25-2010 | 11:24 PM
SolEX01's Avatar
Default CEL / TCS lights on, then off for a while, then on, etc.
Hi,
On my '01 Accord EX V6 Sedan in the past 13 months, the Check Engine and TCS lights have come on for a few driving cycles and turned off. Usually, the TCS light is the first to turn off and the CEL follows after a few cycles. No visits to Autozone for free Check Engine Light check.
When I consistently use BP gas in a certain part of Central MD, the CEL turns off after 1 or 2 cycles. When I use gas in a different part of Central MD, I can sense a difference in drivability (and gas mileage) before the lights flash on. I can use 7-11 gas and gas in PA (10% Ethanol) without issues.
The car drives perfectly fine, 27 MPG on hwy w/o AC and 23 MPG mixed driving with the AC on full blast. Just placed new Yokohoma Avid Envigors up front. Note, timing belt has never been changed - $800+ where I live.
Bad gas? Coincidence? Thanks.
SolEX01
Old 07-25-2010 | 11:40 PM
Its hard to guess the problem.
Even if the CEL is turned off, I would get the codes read at an Autzone to get an idea of the problem.
Old 08-10-2010 | 03:54 PM
SolEX01's Avatar
Default Followup....
Followup:
On 8/10, I paid a visit to AutoZone who connected their scanning equipment to the car and found the following stored codes (CEL remains off):
P0401 - EGR Flow Insufficient
P0505 - Idle System Malfunction
The car runs perfect - quiet idle and 28 MPG on 2 recent tanks of gas.
Thanks in advance for any suggestions.
Old 08-10-2010 | 05:04 PM
The P0401 is the code I would try to repair first, since that is more common. That is caused by a clogged egr port. Google 99-085.pdf. The second link from just answer shows the repair procedure.
Once you fix that the P0505 may go away.
erniep24
11-21-2014 11:24 PM
Cateastrophe
02-08-2013 06:56 AM
thegeneral71
06-11-2011 06:51 AM
SpeaCKJ
12-21-2008 02:43 PM
drive4fun
08-05-2008 08:28 AM
Quick Reply: CEL / TCS lights on, then off for a while, then on, etc.
