Center Console removal
Old 11-01-2006 | 11:08 PM
MALSR's Avatar
Default Center Console removal
I've got a really bad dash-rattle coming from underneath the shift-selector (automatic transmission). Sounds like a loose screw is just rattling around in there. My question is how do you pull out the cover that goes around/underneath the shifter. Do you have to disassemble the shifter ****? or can you pull it off some other way?
Old 11-02-2006 | 04:16 AM
Default RE: Center Console removal
This job isn't too bad. You'll have to remove the ****. I would suggest buying a Haynes manual. It will give you enoug information to guide you through the job.
Old 11-02-2006 | 11:49 AM
deserthonda's Avatar
do not remove the shifter ****,,,,,,,you got to remove the center console
there are screws on each side of the console , also inside the console , there is a cover, you need to pop it out with a small screwdriver, there are screws under that cover
rah140
11-07-2010 11:59 AM
maro
04-06-2007 11:40 AM
tubbybrown
11-16-2006 02:36 PM
johnc
03-06-2006 05:14 PM
itsmetinh
01-01-2006 11:42 PM
Quick Reply: Center Console removal
