Center console stopped working
Old 09-26-2017 | 01:35 PM
Bowtai's Avatar
Unhappy Center console stopped working
I recently took apart my center console in my 1996 accord to get at the speedometer and put a new shift **** on but when i put everything back togeather the stereo, clock, and cig lighter stopped working. I checked the fuse for the radio and it was blown but after i replaced it it still wasnt working. Is there anywhere else i can look for a problem?
Old 09-26-2017 | 04:47 PM
Did the fuse blow again right away? If so, look for pinched wires or something like that in the console.
Old 09-26-2017 | 06:07 PM
Bowtai's Avatar
It hasnt blown again since i replaced it the first time
Old 09-26-2017 | 07:00 PM
There is a quick an easy way to test your fuses with a volt meter or test light. You test for voltage on the top of the fuse where there is a small metal tab. Search youtube for a good video.
You should test all of your fuses.
Does everything else work properly in the car?
maro
04-06-2007 11:40 AM
tubbybrown
11-16-2006 02:36 PM
MALSR
11-02-2006 11:49 AM
johnc
03-06-2006 05:14 PM
itsmetinh
01-01-2006 11:42 PM
Quick Reply: Center console stopped working
