Chain Case Cover over Timing Belt Tensioner
Old 07-06-2009 | 01:12 PM
JohnAccord2007
Default Chain Case Cover over Timing Belt Tensioner
Hello, Just curious if anyone know: In 4cyl Honda Accord, why does the timing belt tensioner have the separate cover over it? I know this allows the tensioner to be replaced easier (without removing the whole chain case) but
1. Does the tensioner really have to be replaced so often that this is necessary? (I would think it could just be checked/replaced when the timing belt was replaced).
2. It doesn't look like it is possible to inspect the timing belt through this cover, right?
3. It doesn't look like the tensioner can even be checked through this window (since the extension of the tensioner arm cannot be measured from this window), right? So how would you know if the tensioner was bad through this cover anyway?
Thanks for any responses!
John
Old 07-06-2009 | 01:45 PM
Just checking... You're talking about a 2007 (judging from your screen-name)?
It has a timing chain, not a belt.
You check wear on the chain based on how far the tensioner is extended (13.5mm maximum). I don't remember the details of how you measure it...
Old 07-06-2009 | 06:13 PM
JohnAccord2007
Default Yes, 2007!
Yes, Sorry, I am asking about a 2007. Thanks for the info. Just curious why the tensioner has its own cover -- especially since it looks like the tensioner extension measurement (the 13.5mm) can't be made w/o removing the entire engine front cover...
Thanks again!
John
Old 08-12-2012 | 10:22 PM
mhonda49's Avatar
anybody know how to take timng chan cover off on 2003 honda accord. all visible bolts taken off already. should it beable to just pop off
Old 08-13-2012 | 09:35 AM
Dr. Drivability's Avatar
here ya go...
ss485
02-23-2011 09:18 PM
DisplacedMic
01-25-2011 09:51 PM
tradosaurus
05-07-2007 02:08 AM
olorin
01-22-2007 06:22 PM
